Harmony One: Switch everything off except one device?
Discussion in 'Home Cinema Control & Remote Controls' started by HomeyJay, Feb 21, 2014.
  1. HomeyJay
    HomeyJay
    Sep 19, 2002
    126
    cowbridge
    +4
    Because of a recent update, whenever my HTPC is being turned off by the Harmony One, I'm getting the blue screen of death. It never happened before, but I suspect that some recent windows update is causing it.
    Is there some way to turn all the listed devices off at the end of a night's viewing apart from one device, in my case, that's my HTPC?
    I'd like to just turn that off manually to avoid the problems until I get to the bottom of what's causing it!
    I'm sure that there's an elegant way of doing it but I just can't get my head around the problem of including the PC as a device but leaving it immune to the <off> command.
    Any help would be greatly appreciated..
  2. HomeyJay
    HomeyJay
    Sep 19, 2002
    126
    cowbridge
    +4
    <facepalm>
    I found the "leave on all the time" option in MyHarmony.com, under the device settings!
  3. Flimber
    Flimber
    Sep 22, 2002
    13,721
    Yorkshire
    +4,483
    Was going to suggest giving it a random, unused code for that one function :)
  4. Trollslayer
    Trollslayer
    Feb 11, 2007
    25,968
    Poole
    +10,834
    Don't worry, it took me a while as well.
