Harmony One Rattle
Discussion in 'Home Cinema Control & Remote Controls' started by Rolling, Feb 12, 2009.
  1. Rolling
    Rolling
    Nov 20, 2001
    341
    England
    +27
    hi....just got my harmony one today....if i shake it (not vigorously) it rattles like something is loose inside...is this the norm....i emailed logitech and this is there reply:
    Dear andrew,
    Thank you for your recent inquiry about your Harmony Remote
    The rattle that you hear in the harmony remote is the tilt sensor for the remote. The tilt sensor is to turn on the backlight and the glow for your remote when you pick it up. If you have anymore questions or difficulties please let us know so we can better assist you.
    We hope that we were able to assist you in resolving this issue, however if you are still experiencing any difficulties with your Harmony Remote, please feel free to contact us again.
    Regards,
    Harmony Technical Support
    ........cheers andrew
  2. John7
    John7
    Aug 6, 2004
    2,803
    +972
    Yes, it is indeed the tilt switch
    Old tilt switches used Mercury, so no noise but they are not allowed to use that Element these days due to it's toxicity - I think they use a small ball-bearing instead, hence the rattle
  3. Rolling
    Rolling
    Nov 20, 2001
    341
    England
    +27
    thanks john...learn something everyday...cheers...andrew:smashin:
  4. Deputy Dawg UK
    Deputy Dawg UK
    Jan 9, 2006
    1,478
    Rushden, Northants
    +58
    You know i had the same with my 1000 and presumed it was the above but nice to know for certain :)
  5. Pont
    Pont
    Jul 4, 2006
    586
    +91
    :rotfl:
    I was about to email Amazon/Logitec and complain that something was loose in mine!
    Thanks for the post. Saves me a bit of embarrassment!
    :thumbsup:
  6. RorschachUK
    RorschachUK
    Apr 26, 2007
    46
    York
    +11
    Whilst I understand the explanation that mercury's bad, I'm sure there must still be better technologies than a ball bearing - there are tilt sensors in the Playstation 3's Sixaxis controller, for instance, and in the Wiimote. My phone has a sensor, you can change track by shaking it. The mighty iPhone / iPod Touch have very good movement sensors, proving that it can't be a very big component to fit in such slim devices. None of these devices use a ball bearing or rattle when used, and I don't imagine any of them are using mercury unless anyone knows better - the kiddie-friendly Wiimote in particular. Certainly they are all current devices on the market right now, so are all "allowed" to use whatever silent tilt-sensors they are using. What technologies are they using, and why couldn't the Harmony remote use the same?
  7. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    I don't know why not, but I do know that I've never heard anything at all out of my One!
  8. Gerry
    Gerry
    Oct 20, 2001
    251
    My Gaf
    +10
    Thanks for that info, saves me a return trip. Just got one and set it up and only noticed the rattle. Remote works fine but it was a bit disconcerting to hear that rattle like something inside had broken.
  9. Phaedrus68
    Phaedrus68
    Jun 26, 2008
    329
    Dublin
    +12
    Thanks to those posting on this thread - I had been considering returning my One, but my mind is at ease now...
    Mark
  10. molex1000
    molex1000
    Dec 28, 2011
    I can't believe this is the best they can figure out for this, or at least they can't figure out a way to make it not rattle around... I was about to return my Harmony One as well until I (thankfully) googled harmony one rattle... so there you go, I don't like rattling stuff in my remote but over all still pretty happy so far.
  11. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    Welcome to AVF.
    I've had three Ones and never heard a sound out of them.:)
  12. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,128
    Poole
    +10,965
    It may be a quick fix so they could keep shipping, to be honest I am surprised they still used mercury.
    It looks like I have one with the mercury tilt switch BTW, about a year old.
  13. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    So they've changed from a tilt switch to this rattling thing?
