SaShepherd
Hi All,
I have set up a very simple activity for my Harmony One remote and am running into a snag I can't figure out. The activity is to turn on my Yamaha receiver and set the input to V/aux where I have my iPod connected. The activity works perfectly except I would like the remote to be able to control the receiver volume which it will not do unless I access devices and select the receiver first. Is there a way to program the remote so that when I select the activity "Listen to iPod" it turns the receiver on, selects the v/aux input and maintains control over the receiver?
