Question Harmony One and Panny UB900 UHD BD Player
Discussion in 'Home Cinema Control & Remote Controls' started by ahaydock, Apr 19, 2016.
  1. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    Getting my Harmony One ready for when my Panasonic DMP-UB900 4K UHD BD Player arrives but cant seem to find it.
    Thoughts? Or is it just too new?
  2. logiciel
    logiciel
    Feb 2, 2008
    53,062
    UK
    +5,738
    It's far too new, but Logitech will soon catch on to it.
    For now try some other Panas as they'll probably work.
  3. chrispyuk
    chrispyuk
    Jul 26, 2007
    35
    2
    11
    +9
    Not set my Harmony touch up for UB900. But I have been able to use it using the existing setup for my existing Panny Bluray player. I will be doing a full re setup when my new recievers drops in on Wednesday.
  4. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    Which model Blu Ray? Going to set my remote up later...
    Its OK actually as its now on the Harmony App :)
  5. chrispyuk
    chrispyuk
    Jul 26, 2007
    35
    2
    11
    +9
    My UHD player is the UK model. Logitech have 3 variants of the DMP-UB900. I am using the codes for Panasonic DMP-UB900EB with no issues.
  6. chrispyuk
    chrispyuk
    Jul 26, 2007
    35
    2
    11
    +9
    A question about the UB900. Anybody having issues with the sound not been outputted correctly? I have bitstream set for Dolby and DTS and BD secondary Audio set to off. I am currently using the second HDMI(Audio) set to Audio only, but I am only getting Dolby Digital and not Dolby True HD. The firmware is 1.03. I have tried a UHD bluray (Mad Max) and a normal Blu-ray. Both not outputting Dolby True HD(Dolby Atmos). I have tried the Blu-ray in my Blu-ray player, and using the same cable and HDMI input on my receiver, and this works OK. I am pretty confident that it is the UB900 that is a fault. I logged a case with Panasonic but so far not had a reply. If anybody can shed any light on the matter or having the same issues it would be great. I am pulling my hair out trying to resolve it. Clutching at straws I have also powered on the devices in a particular order just in case it was a handshaking issue. TV. Amp. UB900.
  7. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    I haven't touched any settings on the Player and it outputs HD Audio no problems for me.
