Harmony:Moving from "Devices" to "Activities"
Discussion in 'Home Cinema Control & Remote Controls' started by DECKARD71, Sep 21, 2007.
  1. DECKARD71
    DECKARD71
    Sep 7, 2007
    632
    43
    +119
    Hi all. I've bought an harmony 555 folowing your advices (thank you all). I'm delighted with the remote. Just one question: sometimes I need to click on Devices to make some adjustments (i.e. AV) but afterwards I do not know how to come back to the Activity I was running. If I click on Activities I get the list of Activities, but what I want is to come back to "watch TV" for instance, not to click again on "watch TV". How can I do that?
    Thanks!!
  2. THE_FORCE
    THE_FORCE
    Jan 15, 2007
    7,185
    My own ikkle world.
    +4,454
    Hi Deckard. All you need to do is just click the activities button again, and all your buttons will still be set up for the activity currently in use. You don't have to press "watch TV" again! :smashin:
  3. DECKARD71
    DECKARD71
    Sep 7, 2007
    632
    43
    +119
    Hi The Force. I've tried that, but if I click on "Activities" I do not come back to "watch TV", I come back to the LIST of activities.
    However, last night I saw that if I click on "devices" again, I came back to the activity I was before (watch TV) but this morning has not worked....
  4. THE_FORCE
    THE_FORCE
    Jan 15, 2007
    7,185
    My own ikkle world.
    +4,454
    Hi Deckard, with my 555 anyway, the list of activities does come back up, but all the buttons should still be configured for the last activity you used. So just ignore what the screen says and carry on using the buttons as you would normally! :thumbsup:
  5. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,784
    Newbury
    +255
    Deckard: hitting 'devices' again is the right way to get you back. You may have to do it once or twice (once to bring you out of your device and once again to bring out of the choice of devices menu).
  6. DECKARD71
    DECKARD71
    Sep 7, 2007
    632
    43
    +119
    Yes, the remote buttons work for the last activity used, but I have many additional butons configured for each activity, and if I do not come back to the activity, these buttons are not displayed (what it is diaplyed is the list of activities). Most of times I can return to Activities, from Devices, by clicking again on Devices.
  7. czzer
    czzer
    Mar 2, 2005
    719
    43
    +105
    The correct way is to either press the "Device" button TWICE, OR the "Activities" button TWICE. Both methods have the same effect.
  8. veryexcellent
    veryexcellent
    Jan 31, 2007
    +8
    I press activities twice on my 895, I'm guessing it'll be the same on the 555.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    YOu should very rarely need to go into device menu the AV sleection should be done by the activity operation
  10. DECKARD71
    DECKARD71
    Sep 7, 2007
    632
    43
    +119
    Yes, the solution is as simple as clicking twice on Activities or Devices. Thanks for the comments
  11. Broadsword
    Broadsword
    Oct 30, 2005
    3,741
    103
    +454
    Yes but if somethings happens when selecting the activity, i.e someone walks past the remote or you drop it and the signal doesn't get sent, you do need to go into activities.
    Which is why the OP said sometimes.
  12. czzer
    czzer
    Mar 2, 2005
    719
    43
    +105
    I agree that it is sometimes necessary to use device mode, but for the example you gave you would just press the "Help" button to fix the synch problem.
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    and as czzer states thats exactly why it has the "Help" button
  14. amorenod
    amorenod
    Sep 17, 2002
    483
    28
    +41
    The Help button is excellent & invaluable for my father, but I find it somewhat slow, there're at least 2 questions before the input question. To avoid that, I've set the Prev button to be TV Input selection across all activities.
  15. Broadsword
    Broadsword
    Oct 30, 2005
    3,741
    103
    +454
    Yeah I'm in and out of devices quicker than help. If its the last device it gets to before the problem, you could have it sorted 3 or 4 times over.
    i.e device, Amp, On
    or, is TV on, is Sky on, is amp on, is input 2 correct, is input sky correct, did that solve the problem, blah blah blah and so on and on......
    Its just easier, assuming of course you can spot the problem, otherwise help sorts it.
    And obviously you can need commands that haven't gone through to the activity button mapping.
