Harmony H885 - No matter what I do ...
Discussion in 'Home Cinema Control & Remote Controls' started by dUnKle, Aug 29, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    I always have to use the help button to get it to turn my Sky+ off
    Its down to turn off all unused devices but it never goes off - also when I press the main off button on the remote it stays on
    I have to use the help button and when I say NO to is it off it goes off
    Have run setup and troubleshotter 3 times today and no joy
    anyone else have same problem
  2. Rambles
    Rambles
    Jul 14, 2004
    8,313
    UK
    +1,286
    Yes, couple of niggly problems with mine too - it always puts the plasma on the wrong input when turning everything on from off. And it always takes 3 attempts to switch my amp off. I haven't tried to fix it - will try the troubleshooter and maybe phone support eventually..
  3. mark.king
    mark.king
    Jan 25, 2005
    192
    Bradford
    You should phone support they are really good. I would try and re-learn the sky power button as it sounds like the code just doesn't work. I have a Denon 3910 dvd and the menu command was wrong so I learnt the command instead of the one in there database and this worked. I also passed this on to them so they could correct it
  4. Ged
    Ged
    Apr 29, 2002
    943
    +24
    I have this problem with a Panasonic plasma, INPUT press causes a duplicate INPUT 1 source, maybe the same problem?
    It can be fixed, depends on your input switching or delay settings.
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    Well still having the problem
    No matter what I do the remote NEVER switched Sky off unless I use the help command
    I have taught the Harmony each and every remote code from the original Sky+ handset but no matter what I do the Sky+ box stays on :(
    It never even switches off with the main OFF button and I still have to use the help command to get it to work
  6. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    There is an 'always on' setting somewhere. This overrides everything; even the off button will not alter this. Is it possible you have enabled this. It is probably in the devices set up somewhere not the activites set up.
    Richard
  7. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    Cheers - its rather well hidden but works and now I am sorted - thank you
  8. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Thank you; Glad it worked; :thumbsup: just a long shot.
    Richard
