Harmony h655 advice please
Discussion in 'Home Cinema Control & Remote Controls' started by kevH, Nov 18, 2004.
  1. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Been reading all the reports on the learning remotes here and sorta fixed my mind on the Harmony.
    Can someone please advise if the Harmony controls Sky+ and if it can learn basic functions for remote window blinds and a Lintronic Uni2 lamp dimmer?
    Also i cant seem to find out any "codes" for a Jamo DVR50 home cinema dvd player so if no code is available is the Harmony capable of learning the vast majority of the functions for the DVR50?
    Any help would be welcomed and anyone who has one what do you think as £100 at Dixons seems a fair price
    kind regards
    kevin
  2. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    I can't help you with the remote window blinds or lamp dimmer, except to say that the latter two must be IR controlled, not RF.
    The Jamo DVR50 is in the system. Take the route:
    1. Add a device.
    2. Select DVD.
    3. Select Mini System(DVD,CD,Radio).
    4. Select the manufacturer.
    5. Enter the model number.
    6. Save the selection.
    You should check out that it works to your satisfaction and change or learn any controls that do not.
    The Pace and Amstrad SKY+ boxes are also present, enter the correct model No (DRX180 for the Amstrad SKY+)
    N.B. Dixons seems to be the cheapest around.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    As long as they are IR not IrDa it is fine....... just teach the commends from original remote..... to the Harmony
  4. kevH
    kevH
    Oct 11, 2004
    833
    +37
    Thanks a bunch for your help guys
    Checked with the blind and the lamp dimmers both are IR so i should
    be able to "learn" the basic commands.
    Pleased to hear the DVR50 is in there thats made my mind up now
    off to Dixons !!!!
    thanks again
    kevin
