Harmony 895 IR Hex Codes?
Discussion in 'Home Cinema Control & Remote Controls' started by AngelEyes, Jan 22, 2008.
  1. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,635
    Is there a way to input hex codes into an 895? I am guessing not but thought I would ask. I am a complete novice at this so spell it out to me simply :) I have the codes for my Fujitsu screen and wanted a way to select a picture preset when I change inputs.
    Cheers,
    Adam
  2. czzer
    czzer
    Mar 2, 2005
    719
    43
    +105
    Yes, but tech support has to do it for you (this way the new commands are available to all users, not just the person that enters the HEX code).
    Email the code to tech support then follow it up with a phone call. They should add it for you on the spot.
  3. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    +1,635
    Great, thanks.
    Now the tricky part, how do you format the hex code? The PDF I have with all the codes looks a bit complicated with what look like several bits that need to be prefixed before the actual command itself.
    Do you know what the format is?
    Adam
  4. czzer
    czzer
    Mar 2, 2005
    719
    43
    +105
    I'm not sure about that, sorry. Maybe just email them the whole PDF with a note explaining which commands you actually need. They can then extract the info they need.
  5. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    +1,635
    Sounds like a plan, thanks :)
