Harmony 885 will no longer charge in the base station?
frankyknuckles
Is this a known problem? It has been fine since new, it is now about 5 months old and has stopped charging when placed in the base station (no bleep when I place it in or anything).
Will it charge via the USB connector when connected to my PC?
Rebel154
It is a known problem and if you had read the FAQ (see the first thread in this sub-forum), you would have found this out for yourself :cool: .
Have a look here.
frankyknuckles
thanks, now sorted. One of the contacts on the base charges was depressed and trapped and hence not contacting the terminal on the remote..
wiz
Btw
It won't charge via the usb!:eek:
