Harmony 885 - "switching" activiies?
Discussion in 'Home Cinema Control & Remote Controls' started by sirshambling, Aug 28, 2006.
  1. sirshambling
    sirshambling
    Hello,
    I have set up my Harmony 885 so that I have 2 activities - "play TV" and "play DVD" which work fine as stand alone sequences.
    But can anybody tell me how to "switch" between them? If I want to watch a DVD after watching TV for a few hours and then go back to watching TV afterwards for example.
    Thanks. John.
  2. cjn
    cjn
    Nov 5, 2005
    13
    3
    At the risk of being obvious, can't you just press the Activity button then select the one you want from the screen? Works perfectly for me.
    Cheers,
    Chris.
  3. Rebel154
    Rebel154
    Sep 27, 2004
    527
    Doncaster
    +19
    As Chris has said - you just press the other activity button. If you have set it up correctly, the DVD player should switch off, the TV will switch to the correct input if, like me you use a Sky+ box, and again if you have one, your AV amp should select the correct input as well.
    The setup software should walk you through which state each of your devices should be in for a particular activity.
    It works a treat here with my 895 :thumbsup:
