Harmony 885 selecting input
Discussion in 'Home Cinema Control & Remote Controls' started by akseln, Aug 2, 2005.
  1. akseln
    akseln
    Nov 17, 2004
    22
    Oslo
    I have a Viewpia LCD TV. The different inputs are selected by pressing "Input", the use the arrows to scroll up or down the input list, and then select the correct input by pressing OK.
    This works fine on the 885 when switching activities. BUT there is a problem when the input cycling gets out of sync. When pressing Help the 885 tries to correct input. It cycles correct through the inputs choices, but it does not manage to select any input (by sending OK). The only way to correct this is to manually select the input on the TV.
    Anyone else have this problem?
    By the way, is there a way to cycle through inputs both up and down? It seems like the 885 only cycles one way and this is a real pain when you have 6 inputs to cycle through from AV2 to AV1.
