Harmony 885 - Difficulty with Fav Channels
Discussion in 'Home Cinema Control & Remote Controls' started by nheather, Mar 17, 2006.
  1. nheather
    nheather
    Oct 6, 2004
    19,767
    167
    Horsham, West Sussex
    +10,048
    I'm trying to add the final polish to my 885 setup.
    I'm onto the Favourite Channels but I can't get it to work.
    This is my setup ...
    TV is Panasonic Plasma Panel (no tuner)
    Tuner is Sky+
    I have an activity called Watch Sky+ which works fine upto this point.
    When I add a Favourite Channel such as
    Image for BBC1
    Channel Number = 101 which is the Sky channel for BBC1 on update I get an error message
    The 'Watch Sky+' Activity does not understand the command 'ForceState Watch_Sky+_Channel 0'
    Any idea what is going wrong - I can't see that I am doing anything wrong because all I am doing is adding an image and a channel number.
    Cheers,
    Nigel
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    ah i have seen tis bt cant remember the fix, but tech support are open give em a call.........
  3. nheather
    nheather
    Oct 6, 2004
    19,767
    167
    +10,048
    Just got off the phone from Logitech.
    They are trying to fix the problem that Sky have introduced with the Sky Radio numbers - that is given them numbers that begin with '0'.
    The trouble is, the Harmony remote treats the Channel number as numeric so as far as it is concerned
    0101 - a radio channel
    and
    101 - BBC1
    are identical channels because the leading zero is ignorred.
    The radio problem has already been reported and Logitech are trying to implement a fix for it. They admit that in doing so they have broken all Sky Fav Channels whether they are Video or Radio - they anticipate a fix by 21st of March.
    Note - this only applies to adding new or modifying existing Fav Chans - any existing ones will work.
    This is because existing ones will be sending the old algorithm (no leading zero) whereas any new ones or modification will try and apply the new algorithm which isn't working just now.
    Cheers,
    Nigel
  4. cjn
    cjn
    Nov 5, 2005
    13
    3
    I think your error message is a general Harmony problem, caused by using punctuation and special characters in the name of an Activity. Stick to A-Z and 0-9 and the error should go away. I don't think it's connected with the 0101/101 issue.
    Chris.
  5. nheather
    nheather
    Oct 6, 2004
    19,767
    167
    +10,048
    Okay, I'll try that.
    Cheers,
    Nigel
  6. nheather
    nheather
    Oct 6, 2004
    19,767
    167
    +10,048
    Thanks for the info - yep it was because I had named the activity "Watch Sky+". Changed it to "Watch Sky" and all is fine.
    Cheers,
    Nigel
  7. jrussell26
    jrussell26
    Sep 25, 2004
    37
    I've set up my favorite channels for sky in the harmony software, but I can't find anywhere in the remite to let me access my favorites. Does anyone know how to access them?
  8. Webagents
    Webagents
    Jan 13, 2006
    206
    +3
    Press the media button
  9. wiz
    wiz
    Aug 20, 2000
    4,476
    +4,215
    got the same problem! Tried the media button but still no go, any other ideas??
    Thx
    Ossie
    ahh sussed it! Thanks guys, I have to select an activity. will the media button work the same way when selecting a device??
  10. Composite
    Composite
    Oct 8, 2005
    15
    Any news on the update - it's 21st March.
  11. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    Is there a fix for this problem yet?
    Starting a Radio activity with Sky 0104 gives me 104.
  12. Gary_W
    Gary_W
    Jun 6, 2005
    450
    +21
    I was about to start a thread on this to get help and saw this post :)
    I too am trying to sort out radio favourites, but it's having none of it due to ignoring the leading zero. Great shame as all the logos look very nice indeed ;)
    Gary
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    time for one of you to call Harmony CS
