Harmony 885 crashed
Discussion in 'Home Cinema Control & Remote Controls' started by Rambles, Sep 13, 2005.
  1. Rambles
    Rambles
    Jul 14, 2004
    8,291
    UK
    +1,267
    The screen is showing vertical coloured lines, no other display will come up.
    I can't get the battery cover off (won't budge) and the Logitech site is down for maintenance so can't do a reboot via the PC - any ideas?
  2. Rambles
    Rambles
    Jul 14, 2004
    8,291
    UK
    +1,267
    OK, the Logitech site is back up and the reboot via the usb cable did the trick. However, I notice that the backgorund of the screen is slightly bleached in some areas, wonder if the screen has been damaged by the crash.
    Anyone who has this remote - is the screen background colour an even blue, or is there lighter areas? Thanks
  3. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    You can change the background colour can't you?
    HornyDragon did it to a darker blue
  4. Parre
    Parre
    To remove the battery cover gently press down and then easy slide it off. If you use force you will eventually destroy it :)
  5. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    On a similar subject - is it possible to get screen burn-in on the LCD window?
    I am cycling through 5 different pics on the screensaver, but a little worried about burn-in...
  6. bnewbie
    bnewbie
    Jun 2, 2005
    75
    Screen burn only affects plasma and to some extent CRT screens. LCD screens don't have screen burn at all.
  7. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    Great. Thanks :smashin:
  8. Rambles
    Rambles
    Jul 14, 2004
    8,291
    UK
    +1,267
    How do you do that then?
  9. lee_car
    lee_car
    May 16, 2005
    579
    Oldham
    same with mine, it started round the edges but has worked inwards, looks like the coulors are fading so ive sent it back to CCL and ill see what happens :thumbsup:
    lee
