Harmony 885 charger problems... a fix that really works.
Discussion in 'Home Cinema Control & Remote Controls' started by Jules, Aug 28, 2005.
  1. Jules
    Jules
    Oct 11, 2000
    5,584
    134
    +1,045
    Like many owners of the harmony 885, mine will not sit snuggly on the charging base so it constantly beeps and stops charging at the slightest nudge.. not to mention that it takes 3 or 4 goes at sitting it correctly to start charging.
    Logitech's suggested fix is to put tape over the 2 recesses on the base. Whilst this helps, it is not perfect.
    It still takes a couple of goes to sit correctly, and the once on the base it swings about at the bottom because it cannot 'sit' in the recesses.
    It also makes the base look a bit tatty.
    But, don't despair.... I have a fix that really works, albeit still using some tape.
    Cut thin slithers of black insulation tape, and effectively 'line' the recesses on the base with 3 or 4 layers of it (you may have to poke it in a bit)..
    This raises the height of the remote very slightly on the base to make good contact and still allows it to fall inside the resesses to prevent movement. I did it very carefully and you cannot see the 'modification' either.
    Now I just chuck the remote on the base and charges every time!
    Hope that helps.
  2. Rambles
    Rambles
    Jul 14, 2004
    8,470
    UK
    +1,352
    Don't fancy posting a picture do you?
  3. Jules
    Jules
    Oct 11, 2000
    5,584
    134
    +1,045
    Sorry Lisa, my digi camera is at my sisters.
    It probably wouldn't show up on a picture anyway.
    To clarify though, I cut strips of black insulation tape just under the length of each recess, and about 5mm wide. Then I simply stuck them to the bottom of the recess in layers...carefull poking them with a pair of tweezers so they didn't wrinkle.
    After a couple of layers it was a bit better, but after 4 layers it was perfect and practically invisible.
