Harmony 885: Change the current "Device" after activities start
J
jih
Amongst my config I have an XBOX360 which I would like to start in "Media Center" mode.
I have programmed a button on the 885 as the "start" button but the way I have set up the activity I only see the options for the TV in the display and to access all the media center functionality I need to then press "devices" and select "media center" from the list.
I would like my display/settings to default to the media center after switching on the TV and the XBOX - if you see what I mean?!
Any thoughts?
Thanks.
James.
czzer
You can add whatever commands you want to your activities.
Activity -> Customize -> Change behaviour of buttons
J
jih
czzer,
Thanks - that is what I have now done which was a bit long winded as I had to program each button to be the same the actual devices.
I was hoping to simply change the default device to x from y and use the buttons as already programmed.
Cheers.
James.
czzer
Yes, but the Harmony is an ACTIVITY based remote, so there is no "default device" when you enter an activity. It controls a combination of devices used in the activity.
