Harmony 885 and Arcam AVR300
G
GarethL
I am trying to get a function listed in my Arcam AVR300 manual's IR Remote Codes section working with my Harmony 885.
The manual says the codes are based on the Phillips RC-5 standard.
The commands I want to add are
System Code 16 command Code 16
System Code 16 command Code 17
How knowing the codes do I then program them into the Harmony.
They are not available as selections when setting up the AVR300 on the Harmony, thay are also not available on the original remote control to program from.
Any help much appreciated.
richardbarman
System address 16 is set aside for 'pre-amplifiers' and codes 16 and 17 for vol+ and vol-. Chances are that if you put in some spurious bit of Philips pre-amplifier kit into the harmony set-up, and use the volume up and down commands, the codes will work.
Richard
R
rowan_moor
Alternatively just email what you posted here to Harmony support and they will add it for you.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
