Harmony 855 & Sky+
Discussion in 'Home Cinema Control & Remote Controls' started by Tim-Ann, Jul 18, 2005.
  1. Tim-Ann
    Tim-Ann
    Jan 18, 2005
    3,264
    71
    Bradford
    +99
    Hi there,
    I can't seem to get my 855 to not jump 2 programs on Favorites and if I go into Guide on the 855 it just jumps 2 steps I've tried following the troubleshooting on the Logitech web site but it keeps saying it cannot change the values down from 3 to 2 or 1.
    Also want to use the blue button on the remote to work as on the Sky+ remote and I can't get this to work.
    Have used the web sire to set Skyplus as the input am I missing something?
    Many thanks for any pointers, Tim.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    teh double jump is a delay setting (easist to ring CS in canada) and to use the coloured buttons you may need to edit the button mapping
  3. Tim-Ann
    Tim-Ann
    Jan 18, 2005
    3,264
    71
    Bradford
    +99
    Hi there,
    When I try to alter the value from 3 to 2 or 1 or set the colour buttons on the 855 I get this error message.
    'Your Satellite tried to set the Sky state to the value 'SetValue 2427718_Input Sky', which is not one of the values defined for that state'.
    Tim.
  4. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I had the same problem on my 655, in the end I simply re-taught the remote the code for all the colour buttons.
    Problem is I emailed customer support they changed the repeat times, however that stopped repeat working on the direction buttons.
    Hope that helps.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    hmm sounds like the original Sky+ code in the data base may be a bit iffy
  6. dvd.collector
    dvd.collector
    Mar 28, 2005
    45
    +6
    I had this problem (the jumping 2 steps) - will confirm later tonight what I did to fix it. (Was somewhere on the Logitech site.)
    Also I noticed the colour buttons werent mapped by default, but its easy to add them using the website, then updating your harmony.
  7. Tim-Ann
    Tim-Ann
    Jan 18, 2005
    3,264
    71
    Bradford
    +99
    Hi there,
    dvd.collector look forward to hearing if you have a solution will call logitech if not after all it is a free call.
    Many thanks, Tim.
  8. dvd.collector
    dvd.collector
    Mar 28, 2005
    45
    +6
    Sorry didnt get chance to look last night, am away from home at the minute.
    There is an option on the 'troubleshoot' menu where you can change the number of repeats to 0. When I finally get home, I'll take a screenshot.
  9. Tim-Ann
    Tim-Ann
    Jan 18, 2005
    3,264
    71
    Bradford
    +99
    Hi there,
    Sorted, phoned Logitech this afternoon and they did it all for me from their end, now works like a dream until I encounter the next problem.
    Many thanks for the pointers, Tim.
