Harmony 785 - charging question
Discussion in 'Home Cinema Control & Remote Controls' started by tmarkr, Jan 2, 2007.
  1. tmarkr
    tmarkr
    Feb 11, 2006
    47
    Just unpacking and sorting out new Harmony 785: popped it on its base and it lit up, so i could see it was charging... then it went to black, no sign of any charging symbol. Is this what should happen?!
    If so, how long does it take to charge and/or will it illuminate again when fully charged!?
    thanks
  2. martin purnell
    martin purnell
    Jun 28, 2005
    542
    28
    +50
    I received mine yesterday as well! Assuming you put in the battery casing that was wrapped up separately (stranger things have happened) you should have been able to get some commands to work when attaching the USB to the computer. I found that unless I was downloading the command updates, I could leave the 785 charging on the cradle. Mine took about 6 hours to fully charge. Hope this helps.
    Martin
  3. James.Bowman
    James.Bowman
    Jan 5, 2007
    163
    28
    +22
    Yes, this is completely normal. When you place the Harmony in the cradle, the display and back light go off after a couple of seconds.
