Harmony 688
Discussion in 'Home Cinema Control & Remote Controls' started by bcopping, Jul 5, 2005.
  1. bcopping
    bcopping
    May 24, 2005
    508
    28
    Brecon
    +46
    I got my harmony 688 this morning!! it looks good so far, basic setup was easy enough. However i cant seem to bring up teletext, any ideas? (working with panasonic tx-28pl1)
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    has the correct button been assigned? did you download your TV setup from the logitech site, as its always possible that someone has misprogrammed the codes
  3. bcopping
    bcopping
    May 24, 2005
    508
    28
    Brecon
    +46
    what is the correct button? there doesnt seem to be one!
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try learning the code to the HArmony remote from the panny one and assign it to the screen
  5. bcopping
    bcopping
    May 24, 2005
    508
    28
    Brecon
    +46
    That did the trick! set the "Guide" button to launch teletext. :smashin:
    didnt need to learn it though the option was there whilst assigning buttons for the activity! Thanks.
