kbfern
Hi Guys I have a Harmony 688 which controls my Sky HD, Humax PVR and HDDVD player.
I is configured to work through my Denon 3802 amp,the thing is I am swapping the amp out for a Yamaha RX V2700 and at the same time adding a Wii into the system.
The question is do I have to totally reconfigure from scratch or can I just remove the amp settings from the Harmony and replace with the Yammy amp.
I have the remote hooked up to the pc with the software running but it does not seem to give an option to replace the amp.It says do you want to rename, is this the same thing or not.
Am I better to do some sort of factory reset and start again or is there an easier way.
Thanks Guys
Keith
Thanks Guys
Keith
