Harmony 688-Any UK Stores Stock This?
Discussion in 'Home Cinema Control & Remote Controls' started by Beancounter, Feb 11, 2005.
  1. Beancounter
    Beancounter
    Aug 22, 2004
    1,827
    +53
    I am really keen on the harmony 688 but would like to see one in the flesh so to speak before i buy. Does anyone know of any stores in the UK that stock this or failing that the best place to buy online?
  2. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    I don't know of any shops, but you can buy it direct from the Logitech online shop.
    Logitech shop
    It costs £119. :)
  3. maclynn
    maclynn
    Feb 5, 2005
    41
    Check the 688 before you buy. They are very good but the buttons are not easy to find.
    The 655 is available from Dixons or on line from Logitech and is similar but with a better button layout. It aso has red blue green and yellow hard buttons which can be useful.
    It is also slightly cheaper.
    Mike.
  4. Beancounter
    Beancounter
    Aug 22, 2004
    1,827
    +53
    I was wanting the 688 as it is better for PVRs according to the website. As I have Sky + and a Fusion PVR then I thought that would be a better purchase.
    I went into Dixons last weekend knowing they stocked the 655, couldn't see one on display so asked the assistant, got a typical Shaun of the Dead look! :confused:
  5. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    I can't see why the 688 is better for pvr's, I run my Humax pvr happily from the H655, and it has the coloured buttons as mentioned.
    p.s. the Preston Dixons had a H655 hanging up with the rest of the aftermarket remotes today. (I also got my H655 at Dixons - in Burnley).
  6. Beancounter
    Beancounter
    Aug 22, 2004
    1,827
    +53
    I have just ordered the 688 from the Logitech website after reading various reviews so hopefully I will get on ok with it. I have had a Kameleon and a Pronto in the past and didn't get on too well so hopefully this will prove a better purchase.
  7. davet010
    davet010
    Jul 23, 2004
    384
    +10
    Bean
    If yours doesn't work, as mine didn't, give their tech support helpline a bell. They were very useful, and identified that the wrong firmware was in it - mine came loaded with version 2.5, not 2.9.
    Now has anyone actually programmed one to work with Sky+ ?
    DT
  8. maclynn
    maclynn
    Feb 5, 2005
    41
    I have a 688 and a 655, both work OK with Sky+.
    I could not remember the model number but Sky plus is in the database.
    Mike.
  9. M@rtin
    M@rtin
    Sep 29, 2003
    466
    28
    Peterborough
    +28
    Which do you prefer?
  10. maclynn
    maclynn
    Feb 5, 2005
    41
    The functions are almost identical but I prefer the 655 as I am an old git and I need glasses to operate the 688 at night.
    Mike.
  11. Demon666
    Demon666
    Jan 6, 2005
    12
    I have a 688 but im having problems with the direction up/down/left/right buttons , they dont seem to scroll like the sky+ remote . Do your's have this problem ??
