Harmony 655 - What if a prolonged press is required??
Discussion in 'Home Cinema Control & Remote Controls' started by IndianaBlues, Sep 7, 2005.
  1. IndianaBlues
    IndianaBlues
    Jul 28, 2005
    2,027
    +355
    I ordered my 655 with my new Panasonic TV from Dixons a few weeks ago, but the TV turned up on Saturday and the remote's in the post somewhere. My query is that on my old Sony TV I just had to hit the standby button for a millisecond to bring the it out of standby. With my new Panasonic you have to hold the standby button down for at least 2 seconds before the TV fires up. Can this be accomodated within the Harmony, or will it simply send one-press, fixed-length signals?
    Thanks,
    Nic
  2. sneekyb
    sneekyb
    Yes you can increase or decrease the signal time via the online setup.
  3. cuk0724
    cuk0724
    Mar 8, 2003
    20
    London
    I had this problem with my Slimdevices Squeezebox2. The Stop command is a long Pause command (if that made sense).
    I got it to do it by teaching the remote the raw data for a long Pause command.
  4. dnoyce
    dnoyce
    Jun 10, 2005
    4
    Thanks for asking this question because I have been trying to find the answer to exactly the same problem. Quite why Panasonic TV's require such a long on/off signal is a mystery and it has rendered my present remote useless as far as macros go. That's progress!!
    David
