Harmony 655 verse 525
Discussion in 'Home Cinema Control & Remote Controls' started by Grobnic, Nov 6, 2005.
  1. Grobnic
    Grobnic
    Jun 21, 2005
    115
    16
    Chelmsford
    I've just ordered a new TV and I will need a universal remote to run all my kit now, so I've been looking at options.
    Logitech seems to get very good remakes on it's service level so I think it's between the 655 and the 525. The 525 looks sexier but I can't see what it does the 655 does not.
    Can anybody enlighten me as to why the 525 might be better that the 655 (or the other way around :confused: )
    Any comments would be helpful
  2. jriihi
    jriihi
    Mar 6, 2005
    196
    16
    I would get 525 because it looks better :)
  3. msg
    msg
    May 20, 2005
    471
    Darlington
    +12
    Functionality basically identical; down to looks and feel at the end of the day. See comments on 525...
    http://www.avforums.com/forums/showthread.php?t=240272&page=3
    However, 655 has additional 'picture' and 'sound' buttons which enable direct access to adjustments throughout your activities (I've used soft buttons on the LCD on my 525 to get exactly same results).
    Note though, the colour buttons on the 655 have replaced the 'exit', 'info', 'menu', and 'guide' buttons from the USA version (650).
    I've noticed that the red and blue buttons on the 655 are supposed to undertake dual functions - 'exit' and 'menu' (which could be confusing). Also, 'guide' is just below the LCD and 'info' is nowhere to be seen. So layout is not logical for these functions.
    If you have a PVR, DVB equipped TV, Sky or freeview box, then the H525 would be the easier one to use.
    Dave ;)
