Harmony 655 sky+ menu jump problem
Discussion in 'Home Cinema Control & Remote Controls' started by kevH, Dec 1, 2004.
  1. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Having problems with my Harmony 655 jumping 2/3 times when scrolling thor the Sky+ menu and the Sky programme listings !!
    Anyone with the harmony managed to sort this ??
    Calling Ikki or Hornydragon !!!!
    Kevin
  2. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    Try re-learning the SKY+ buttons rather than relying on the ones in the database SKY+ device record. My PVR8000T behaved strangely before I did this. At least you will know that the remote is giving out the correct commands.
    Go to the device 'More options' then 'Learn infra red commands'. It just takes a minute or two.
    If they still don't work try learning them as raw commands.
    1. Click More Options beside the device on your Harmony home page.
    2. Click Learn Infrared Commands.
    3. Click Custom. The page will reload.
    4. Select the boxes for commands you would like to teach, and click Learn Selected as Raw.
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    I have been having this problem on my Manhattan satellite receiver.Many times I have used the learning section,and even learning the commands raw solved nothing.
    Needless to say,the Harmony is on its way back to Dixons until their database is more updated.
    Back to Marantz
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    phelings if you phone HArmony CS in canada they can sort far more out than users are allowed to via website...... I think your decision may have been a tad hasty.....
