Harmony 655 Setting Up?
Discussion in 'Home Cinema Control & Remote Controls' started by wokeye, Aug 26, 2005.
  1. wokeye
    wokeye
    Apr 15, 2003
    655
    +61
    I have just bought a Logitech Harmony 655 remote due to recommendations on here and I have to say that my initial impressions are that this is an awesome bit of kit. Had a few niggles setting up my Hitachi TV, but soon got it figured. The only other things I need to do is setup a few other functions to make it perfect. When using the softkeys for functions on my TV one of the features that I use very often is the AV button to flick through the devices that are connected by scart leads, however I have to press the "Next" button a few times to get to this soft key on the display screen, is there a way of programming the remote so that this button would be one of the initial commands to appear on the softkey menu once I set the TV as my device? Or will the remote learn that I use this function often and move it there itself? Or could I just program another hard key on the remote to operate this function?
    The only other minor gripe that I have is that when I am moving through Sky menu's using the arrow keys the Sky moves down through the menu's slower than when I press the button, I am assuming that there is a way to adjust the time in which the remote sends the signal to the digibox?
    Apart from this the control is simply awesome value for £50 :thumbsup: Awesome bit of kit :)
  2. jaymz
    jaymz
    Mar 29, 2005
    1,015
    Sunny Norfolk
    +60
  3. wokeye
    wokeye
    Apr 15, 2003
    655
    +61
    Thanks for the help jaymz :thumbsup: Got this remote sorted now and all I can say it is an incredible piece of kit for £50 very well impressed and would recommend it to anyone :clap:
