Harmony 655 key response Sky +
Discussion in 'Home Cinema Control & Remote Controls' started by ndenbow, Dec 1, 2004.
  1. ndenbow
    ndenbow
    Oct 20, 2003
    482
    Herts
    +11
    I have just configured my Harmony 655 for use with my TV, and in particular my Sky+ V2 box.
    The keys don't appear to respond as quick as my original Sky controller. Is this something I have to accept, or can I fix it with a setting?
  2. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    Adjust the button timings, probably the interkey delay. They are often set to 500ms, drop them to 100ms and try again.
  3. ndenbow
    ndenbow
    Oct 20, 2003
    482
    Herts
    +11
    Seems better, but I can't get my plasma powertoggle to work. I've tried setting the signal timeout to 10000ms and tried the learning thing, but still no joy. Very frustrating. You would think Logitech would get this sorted.
  4. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    Learning will only make it send the correct commands. What exactly is it not doing correctly with the power toggle?
    Which plasma do you have?
  5. ndenbow
    ndenbow
    Oct 20, 2003
    482
    Herts
    +11
    I think this has been sorted now. I have a Pann Viera, which I think a few people have had problem with. I basically did a 'learn raw', because you have to hold down the power button for a couple of seconds to get the thing to switch on/off. Now all I have to do is figure out how to teach the remote to switch input, because that requires a similar thing albeit with 2 button presses.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    phonig HArmony CS (Logitech bought harmony didnt develope it) usually sorts all the small niggles out....
