harmony 655 help please
Discussion in 'Home Cinema Control & Remote Controls' started by dubledene, Apr 2, 2005.
  1. dubledene
    dubledene
    has anyone had any joy at programming the following for their harmony???
    sony kd36nx200 tv
    sony rdr gx7 dvdr
    vsxd-912 pio
    pace v2 sky +
    i ask as im having trouble setting these up so any help would be gr8 ta
    also i cant even get this remote to look at my cd player
    ax-m77 hitachi cheepo player
  2. flipside
    flipside
    Jan 24, 2003
    84
    Brighton , UK
    i know this is abit of a cop out answer but have you tried contacting there help line / email as i found them very responsive and quick to fix any issues i threw @ them hell they even got back to me on a sunday eve after i sent an email that morning.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    not tried the kit you have listed but have got them working most things..............phone CS (open odd times as located in canada) and if you have any major issues LMK i will try and help (remember its not a device by device remote but an activity remote, set-up the activities properly and take it from there.................
  4. Gary D
    Gary D
    Jan 9, 2002
    7,784
    +838
    how can you not get it to work? if the database doesn't know your kit, then just get it to learn the IR commands? once you have the IR working you can start to mess about with the activities.
    it took me about a week to get mine as i wanted it (there are still a couple of things it cant do - but thats the kits fault not the remote.)
    Good luck :)
    Gary
