Harmony 655, device mode?
Discussion in 'Home Cinema Control & Remote Controls' started by spook, Nov 23, 2004.
  1. spook
    spook
    May 18, 2004
    157
    hi all,
    how easy it it to use the harmony 655 in a similar way to one4all devices, ie in "device mode"?
    or are you kind of forced to use the "watch TV, watch a DVD," macro type deal?,
    and can anyone tell me is there a limit to the number of learned commands on the 655? (ie manually scanned from another remote),
    cheers, Spook
  2. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    There are device buttons for each device acessed by pressing the 'Device' button first, this brings up the individual commands for each device.
    I guess that the utimate limit will be the internal memory, but I have not seen any stated limitations.
