Harmony 655 Custom labels
Discussion in 'Home Cinema Control & Remote Controls' started by jaymz, Jul 7, 2005.
  1. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    I have been trying to modify the custom buttons/labels for the LCD on my 655 and at the moment they are all the same for every activity, picture and sound option.
    Is this a limitation/default or can you have a different set for each activity and/or for each picture/sound option?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    you can add or remove any functions of "in use" devices to the LCD Surrond mode and aspect ratio are two i have added to the activity LCD controls as there are no suitable hardbuttons for these on the 655 i also added menu and exit for the Watch TV activity as that allows me to use the coloured buttons which Exit and menu are mapped too (red & blue) as normal colour functions for Digital TV etc
  3. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Thanks for the quick reply but......
    I am not sure if you have answered my question or whether i asked it correctly.
    I have;
    Watch DVD activity with custom buttons which has
    Display - DVD time left
    Aspect - PVR apect ratio
    Watch PVR activity with custom buttons which has
    I also want to do want you have with colour buttons for PVR have specfic functions. Therefore i want;
    Aspect - TV apect ratio
    Exit - Exit
    Menu - Menu
    Favourites - PVR Favourites
    List - PVR scroll list of programmes summary
    Need to make sure i am not being dumb long day at work!
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    yep can do that no worries mate easily done you need the page that has the drop down lists of the buttons whwere you can edit what function each hard button is mapped too and the and custom labels for functions on the LCD you can fit 4 to a screen if you have the activity displayed at the top or 6 if you dont I'll take a pick of mine so you can see how it looks:
    EDIT here you go Mate only issue is they appear in a specific order that you cant change unfortunately so you have to live with where the software puts em
  5. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Cheers Horny but your photos are both of Watch TV and both have the same items for the hard buttons.
    Do you have a different Activity that has different hard buttons?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    do you mean the soft buttons? i will take a pic of "watch DVD" later and see if i have different functions (sure i have some different)
    Favourites could be mapped to guide, the photos were just to prove what can be added the only limit is the number of characters
  7. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Not sure what the buttons are called but the ones next to the LCD!!
    when i added a different item for the picture function of watch dvd it appearred on the picture function of watch pvr
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    ah ok the ones next to the LCD are what i would call "soft" buttons are you using a DVDplayer HDD recorder? all in one unit?
  9. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Update signature with kit
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    here we go 2 pages so you can have 8 soft buttons
  11. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,601
    Aberdeenshire
    +181
    here you go Mate only issue is they appear in a specific order that you cant change unfortunately so you have to live with where the software puts em[/QUOTE]
    I may very well be wrong here, but from what I have experienced, the soft buttons will appear in the order in which they are entered on the website.
  12. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Cheers Horny..
    Now the real questions is; Do you have the Watch TV Activity and the Watch DVD Activity active in your configuration at the same time?
    That is to same when you updated your remote with the DVD activity it did not wipe the TV LCD options!
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    nope never had it do that different soft buttons for each activity time to call tech support i reckon
  14. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    another late night then!
    Cheers for your help.
  15. darrens
    darrens
    Nov 2, 2003
    97
    I've got a different set with each activity but sorry no pics. I just choose the activity and go into change button configuration screen (or whatever it's called) and then just stick the ones I want on the bottomm
  16. captain747480
    captain747480
    Feb 20, 2005
    +11
    This is just a thought that occured to me and I haven't got time to check it at the moment.
    AFAIK the Remote sorts extra commands firstly in order of the device which the commands are for and then by the order you specify on the setup screen. So for my Watch TV setup the commands for my TV always end up before the commands for my STB
    As an example, if device 1 has command1 and command3 and device 2 has command2 and command4 then they will appear on the remote in this order
    command1
    command3
    command2
    command4
    My thought is, what if you learn the commands from device2 onto device1? Could you then order them whichever way you choose?
    I will check this out when I get the chance unless someone else beats me to it.
    Captain747480
  17. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Just done some testing on the Harmony website (but not update my remote)
    Watch DVD activity has the following listed as below but my remote lists them as numbered;
    Chapter + 4
    Chapter - 5
    Display 6
    Audio 7
    Mute 1
    Input Next 2
    Aspect 3
    Input DVD 8
    I am numbering them 1 2 first row, 3 -4 second row, 5-6 first row screen 2,7-8 row 2 screen 2.
    I then deleted ASPECT and InputDVD from DVD activity (these are used on my PVR-AMP activity).
    I then went to the PVR-AMP activity and they were deleted from there!
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    What do you mean by PVR-AMP activity???
    YOur activities should be Watch TV, Watch DVD, Watch PVR etc
    for watch TV you may just TV or can use TV and AMP, for Watch DVD you use TV DVD and AMP, for Watch PVR you use TV, PVR and AMP if you want is this how you have it set up?
  19. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Yes this is how i have set it up. I have Watch PVR (with audio from TV) and Watch PVR-AMP with from receiver.
  20. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    hmm I am not sure whats going on mate have you contacted logitech support?
  21. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    not yet busy weekend. I will try and do it this weekend and let you know how i get on. Cheers for your help.
  22. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Just got off the phone to CSS - It was user error!! :suicide:
    I had set the custom buttons under the TV, video display function therefore the custom button is displayed in the LCD for every activity that users the device.
  23. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    so are you a happy harmony camper again mate? I have only ever found one real issue with the harmony design/system otherwise it is flawless and CSS are so chuffing good, polite and fastwhy cant everything be like this? this forum does alot of customer support manufacturers with harmony there is no need, just call them up and let them do their Job.........................
  24. jaymz
    jaymz
    Mar 29, 2005
    1,011
    Sunny Norfolk
    +60
    Yes, thanks for all your help.
    now should i change my 655 for a 885..............
  25. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    thats a tough one but now you see the potential of the harmony system the 885 is the way to exploit it i am gonna reprogramme my 655 for the bedroom i think and keep the 885 for lounge
