Harmony 655 - can adjust sensitivity controlling volume?
dickst3
I have a Teac Ref 500 amp and when I select the volume on my 655 it moves the volume too high on the amp, so I have to keep getting up and adjusting it manually! :eek:
Got any ideas? :lease:
Richard46
Have you tried
Device (amp obviously :)) Troubleshoot
Choose other problems
Choose Amp doesnt receieve every command corectly
Choose The device responds too much to some commands
Then choose a lower value on the list that comes up etc
Richard
zest
i had this problem with my nad amp, just phone the support centre which is free phone. The chap adjusted my settings now its perfect!!
shahedz
Richard46 said:
Have you tried
Richard
Had the exact same problem on my LINN and done as Richard suggested and it sorted it out no problem!
dickst3
Thanks for all the responses. :smashin:
I will probably have to contact support (at the weekend?) as I cannot get Norton off! :(
Trending threads
