Harmony 655 and Scart Switch Boxes
Discussion in 'Home Cinema Control & Remote Controls' started by Nachos, Feb 3, 2005.
  1. Nachos
    Nachos
    Nov 16, 2004
    32
    Can anyone confirm if my harmony 655 will work with the Hitachi AV centre sold in argos or the Quintro+.
    They are both 5 to 1 scart switches with ir remote controls.
    I don't really fancy hours of manual teaching for the remote. But if i have to i will do it.
  2. DarkKnight
    DarkKnight
    Feb 3, 2005
    197
    +7
    I just tried setting up the Hitachi as an AV Switching device, but it's not a recgnised manufacturer.
    Nevertheless the codes can be programmed into the Harmony... And beleive me when I say you're mistaken that it will take hours to teach the Harmony.
    This is not the Pronto world! I've managed to configure an entire DVD's remote command set within half-an-hour.
    The Harmomy website does the work for you.
    Provided the device in question accepts IR codes, the Harmony will do the job.
