Harmony 655 Activities Problem
Discussion in 'Home Cinema Control & Remote Controls' started by Barzo, Aug 30, 2005.
  1. Barzo
    Barzo
    May 10, 2004
    1,677
    Liverpool
    +422
    Just added new Samsung 32 LCD TV to device, with no problems, or so I thought....
    However, in all activities based on TV, an 'Aspect' command keeps appearing. Can't delete the little sod on the website. If I try, it disappears from the list, only to reapper when you check the commands again. I've also tried changing it to a non-TV command. Altered command remains (and can be deleted), but Aspect comes back as well! :devil: Also, have tried changing to another TV command - works (no Aspect command) but when I delete this, 'Aspect' command comes back! :eek:
    Tearing hair out. Logitech support by e-mail quiet at the moment. Do not want 'Aspect' command on my normal command set (happy for all TV related functions to be in the Picture command subset).
    Anyone any ideas?
  2. johnconway
    johnconway
    I have exactly the same problem. No matter what I do, the 'Aspect' command always appears on the custom LCD display and cannot be deleted.
    It seems that every time I try to reprogram my remote (every few months or so), they have changed their software and my configuration is behaving differently. Last time they have changed the button delay so I have to reprogram all the delay timing.
    Very annoying!
  3. Barzo
    Barzo
    May 10, 2004
    1,677
    Liverpool
    +422
    Have been told by Logitech CS that there is a problem with the wesbite, that will be fixed in the next fourteen days. We shall see...
