Harmony 555 HDMI problem
dicky
I have just brought the above remote, this is for my upstairs equipment (see sig), while the remote has pretty much initially set everything up okay the only problem I am having is getting the "watch dvd" to automatically go to the HDMI input which is the only way I have the dvd player set up.
Normally I would press play on the dvd and then cycle through the inputs on the tv to get to HDMI. Is this something I need to replicate on the remote? I can go into tv devices and on about the 15th!!! page is the HDMI button but this is long winded as you can imagine (a bit like my post :) I was hoping it could automatically go to the HDMI input on pressing the play dvd button?
Any pointers please?
Regards
captain747480
The Harmony is activity based so you should set up an activity called Watch A DVD and in the setup for the activity it should ask you what input your TV needs to be on. Set this to HDMI and when you select Watch A DVD your TV should turn on and select the HDMI input without you having to do anything else.
dicky
Hi - Many thanks - I believe this is part of the problem, the TV inputs
on the harmony site are tuner, ext 1, ext 2 etc but there is no HDMI
input at all!! (although you can get to a dedicated button on the remote
in the devices for HDMI) bit perplexing as I don't know how you add HDMI
to the activity for it to turn onto that input.
Shall have another go tonight
Regards
captain747480
Ok, on the Harmony setup page find your TV Device then select More Options. Now select Adjust Inputs. The first page asks you how you select a particular input, select the appropriate method. Click next and you will be presented with a default list of inputs, you can then edit this list so it matches the inputs you have on your TV.
What model no. is your TV?
dicky
Hi - Thanks for the reply - The tv is 26R51BDX (off top of my head
as am at work). Will work on the above principles you have posted
Many thanks
captain747480
Ok, I've just added your TV to my Harmony setup and I now see how your confusion arises. The initial setup screen only gives you 4 inputs and won't let you change them during initial setup. However, once you've added the device, if you use the procedure I outlined above it will allow you to edit the inputs so hopefully when you get home you should be able to sort it out.
dicky
Many thanks for your help - will try out tonight
Best Regards
dicky
Best Regards
Hi All
Still no joy I am afraid - does anyone own a Samsung TV and a Toshiba
DVD connected via HDMI?
Regards
Paul
captain747480
It might be worth giving Harmony support a call they are very good at sorting out problems. Best to wait until the PM though as their 2nd line support is in Canada.
iamholam
Hi there
If you are saying that you have a direct "hdmi" input button on your remote on the 15th page then there should be the option to select this input without having to cycle through all the inputs.
When in the "watch dvd" activity instead of choosing the av cycling option for choosing an input use the "use specific input" or "use specific" button input option. You should then be able to select the "hdmi input" from the list and then voila! no more dodgy input switching!
I had this problem on my Loewe TV for ages. Just tried working through the input selection process until I realised that I could use discrete inputs to go straight to the input I wanted! :D
dicky
Hi there
Hi There
Yes there is a direct hdmi input button on one of the pages - probably the 15th as you say. I did think I should be able to switch on the DVD activity and go straight to this input though. However I can get to the input - the only thing then is that when I switch back to tv activity it just stays on hdmi, there is no DTV button. Anyway I shall have another go over the xmas period to exhuast all the options etc
Many thanks to all peoples help
Regards
