Harmony 525 question for a newbie
GaryMo
May be a silly question but due to never owning a multi function remote control I just have to ask!!
Ive been looking at a Harmony 525 which should have no problem at all in controling my kit which comprises of:
Samsung LE40R74BD LCD TV
Sony STR-DB780 Amp
Panasonic DVD-S29 DVD Player
Sony S760U Sky Decoder
Xbox 360
If it was programmed to watch a DVD for instance I would expect it to switch on the TV, select correct input source, DVD player and Amp.
After watching the DVD I may want to watch Sky, would it go through a similar process again but this time switching off the TV, Amp but switching the Sky box on or would it already know that the TV and Amp have been previously switched on?
clockworks
It "remembers" the state of each device.
When you change activities from DVD to Sky, it will leave the TV and amp on and switch them to the correct inputs, turn the DVD off, and turn the Sky box on.
ianh64
What happens if the wife uses her remote (the original one for the device) to initially turn the TV on - presumably it gets all confused turns the TV off?
How suitable are the Harmonies if you want to work in device mode.
GaryMo
That makes perfect sense.
Many thanks.
Does the Harmony 525 have backlit keys?
abraxus
Take the original remote off the wife as using that will "confuse" the harmony as to the state of equipment.
Hramony works ok in device mode, and acts like the original remotes, but for 90% of stuff is most suited to activities.
As to other question backlight, I belive it does as the 360 and 555 are backlit.
clockworks
Many thanks.
The keys are backlit, but you have to press the "glow" button to light them. It doesn't have a tilt sensor to turn the backlight on automatically.
n0bby
It does have a sensor that triggers the auto-backlight, but it only operates if the remote hasn't been touched for over two hours. This helps conserve the batteries - which last a commendably long time in this remote.
BTW - if the wife does use the other remote, it's easy to un-confuse the Harmony when the switching gets out of order, by pressing the Help button then following the simple on-screen prompts to get the out-of-sync component back in-sync again.
IMO, the only less-than -great thing about the 525 is the web-based setup routine - it really could be a lot simpler and clearer. But it works, and with a bit of fiddling the remote can be programmed to do everything you want to throw at it. And I've not had to use them, but I hear great things about the support staff, should you get stuck and have to call them.
GaryMo
Agree with the above, especially the ease of putting it back into sequence with the the help menu.
I received mine this morning from Amazon, setup took me around 30 minutes.
The only thing I have a problem with is when initially switching something else instead of general TV. I think it could be the autoswitching 'feature' of a scart lead which could be confusing the operation. Its not really a problem as I just start in TV mode (TV, Sky and Amp to TV) then select either DVD or Xbox 360.
Overall I can't tell you how impressed I am with it :)
A
Abs91
i have another question-i have both a cable (tvdrive) and a satellite box and am interested in the 525. will the watch tv only operate one box or do i get an option for both.
hornydragon
you tell it which one to control so set up a watch TV Sat, and Watch TV Drive activities.
markymark34
I was just about to buy a 525 from amazon when i noticed they have the 688 as well.
which one is better as i cant find a lot of info on the official site?
thanks
Mark
Similar threads
