Harmony 1100 help
johndeere2013
Hi, I have got a harmony 1100 & after some help, I'm not very tech minded . I have sky hd box, Pioneer blu Ray player, optoma projector, connected to Yamaha amp out to Samsung plasma & remote control pj screen. I also have LED lights & I want to use 1 remote to control all this & need to know is the 1100 a good choice & easy enough to set up & use? Thanks
logiciel
It's fine - simply set up your devices, then make them into activities of your choice.
logiciel
OK - let us know if you have any questions.
johndeere2013
Would you say the 1100 is better or the harmony 1? After checking out the 1 on YouTube I may have made mistake in getting the 1100.
logiciel
They're very different. To begin with there is only any point in getting the 1100 if you want to control things without line of sight. Then of course they're totally different in format. Logitech only tried that out twice and have long given it up. My choice would be a One if line of sight was OK, a 900 if not. The only thing in the 1100's favour is the novelty value.
johndeere2013
Think I may sell my 1100 & get the one. It's more wife & kid friendly I think. I do like the 1100, but as you say it's the luxury novelty value. Yes all my equipment is in line of sight just point & shoot.
logiciel
The One will be more than adequate for you, and will be easier to find than the 1100.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
