Harmony 1000 not talking to the Computer
Discussion in 'Home Cinema Control & Remote Controls' started by Sborrone, Apr 30, 2007.
  1. Sborrone
    Sborrone
    Mar 19, 2007
    132
    Buckinghamshire
    +5
    Hi - must apologise if my questions have already been covered - my search technique needs attention!
    I've installed the Software for the remote, connected it up and begun to create my account - so far so good.
    However, when I connect the device to the computer the issue arrises -
    The software installed a "RemoteControl USB LAN Link" which is all very well but why is it looking for an IP Address? I had no idea the H1000 had a built in DHCP server or that the device came IP enabled - if so could someone help me?
    My Firewall and AV software is disabled - help !!!!!!!!!!!
    Before I follow the HornyDragon's view on the unit I'd like to at least have the benefit of testing it !
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    what software version are you using? 7.2.1 doesnt work 7.3 does but isnt available 7.1 is available and should
  3. Sborrone
    Sborrone
    Mar 19, 2007
    132
    Buckinghamshire
    +5
    I'm using 7.3 - Tech support gave me a link to the s/w but I lost the link when I rebooted !!!! Although I do have the software (50Mb) if you have an FTP site let me know and I'll drop it on their for you.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    hmm 7.3 worked for me perhaps try uninstalling and trying agin or using 7.1 7.3 must have issues for them to have pulled it
