Harmony 1000 Line of Sight Question
jezzer256
Hi there. I have a TV at one end of the room, a projector on the ceiling at the other end and a kit rack alone the side of the room.
How can I use a Harmony 1000? Does it require line of sight to all my kit? If it does, I'm stuffed.
Jez
johnmc
just tried mine not pointing at anything in particular and it works fine.
changing channel and volume i am about 6M away.
hope this helps.
J
jezzer256
Oh right cheers. Does anyone know if that's a fluke or is it actually made to work like that?!
Jez
logiciel
My projector behind me responds to IR remote commands directed towards the screen - I suppose they just reflect back.
ajg68
It does require line of sight. It will work at reasonable angles but anything too acute and you'll need to angle the remote toward the equipment.
Like hhatkin I found that the signal can reflect off the TV in front of you and control equipment behind you - so long as you're not blocking the path.
Logitech do an RF extender though that might help you for any non-line of sight equipment http://www.logitech.com/index.cfm/remotes/universal_remotes/devices/378&cl=gb,en
