harmon kardon question
Discussion in 'AV Receivers & Amplifiers' started by technovorgin, Jul 17, 2004.
  1. technovorgin
    technovorgin
    Jun 16, 2004
    233
    Leeds/Wakefield border
    im thinking of buying the h/k 5550 and a set of kef 10005.1 speakers to plug into my panny pwd 6 plasma
    is this a good choice cos its expensive and ill blow all i have
    cheers :thumbsup:
  2. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    i think theres a good deal on both the above items @
    www.edge-sv.co.uk
    should be a nice sounding combination.
    Rozzar
  3. technovorgin
    technovorgin
    Jun 16, 2004
    233
    will the picture quality be good as well?
  4. DonMaico
    DonMaico
    I ahve its predecessor ,avs 5500, and find it a very good amp indeed. You might prefer to wait until they produce an amp with iLink tho as I am told this gives the best connectivity and produces better results soundwise. At the mo there isnt one but every other manufacturer seems to be jumping on the bandwagon so its only a matter of time.If it was me I'd buy a cheap second hand one for now until they release it.
  5. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    well seeing as you haven't mentioned a dvd player, i can't really comment on picture quality.
    just make sure you get one with component output or RGB scart to link into your plasma. Should be plenty at the site i've mentioned above
  6. technovorgin
    technovorgin
    Jun 16, 2004
    233
    bought the ex demo (3 weeks) 5550 :rotfl:
    now im thinking kef 2005 :beer:
