Harmon Kardon AV500RDS
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Paul-r1, Aug 14, 2003.
  1. Paul-r1
    Paul-r1
    May 23, 2003
    102
    Bognor Regis
    Anyone interested in a mint (still in original box with all the paperwork) Harmon Kardon AV500RDS Dolby Digital Amp?
    Reply to this thread if so.
    If it's true we are here to help others, then what exactly are the others here for?
  2. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Do you mean the AVR500? if you do then it's a bloody good amp in both surround and stereo - I know because i've got one.
  3. Paul-r1
    Paul-r1
    May 23, 2003
    102
    Bognor Regis
    I am 99.999% sure it is the same one. I have just had a look at www.harmonkardon.com and it seems to be the same. On the box though, it does have RDS after the title, hence why I thought it was AV500RDS doh! Anyhow...yes....I too think it is an fffffing good amp and I dont want to let it go, but all it is doing is living in it's box on my wardrobe as I have nowhere to set up my home cinema.
    Trouble is, I have no idea what it is worth. If it isn't worth much, then I will keep it. The sound quality is superb, even if it doesn't have the latest 7.1 surround sound !
    I would so def buy HK stuff again. The build quality iteslf is drool inspiring! :rotfl:
    :hiya:
