Harmon Kardon 25 Upgrade Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by ianmidz, Jul 28, 2003.
  1. ianmidz
    ianmidz
    Hi I updated the player using the download on the Apache site and now I cant get the player out of standby - does anyone have any suggestions ? Many thanks Ian
  2. Mr Ed
    Mr Ed
    Jul 24, 2002
    26
    3
    South Manchester
    The correct procedure is:
    Connect to TV via composite cable.
    From standby, press 'clear' on the remote for about 7 secs until the player powers up.
    Load update disc.
    On screen display prompts you to press the 'up arrow' key. (Press it!)
    Disc runs, green bar displayed shows progress, after about 2 mins, player goes into standby mode.
    Press 'clear' for 7 secs or so until the player powers up.
    Remove disc.
    Reset video menu to component, prog scan, 16:9 as appropriate.
    Enjoy.
    Pressing 'clear' for 7 secs resets things.
    Good luck,
    Mr Ed.
  3. ianmidz
    ianmidz
    Have tried it many times and It wont power up no matter how long I press clear - The problem was I switched it off before I Pressed clear for the second time -
    Ian
  4. Mr Ed
    Mr Ed
    Jul 24, 2002
    26
    3
    South Manchester
    Hi Ian,
    I guess it's talk to your dealer time. The disc I have states on the sleeve that Harman will not regard any failures while modding players as warranty jobs, so be careful what you say. If it's less than 3 months old, Harman operate a 'no quibble' replacement policy on failed units.
    Good luck,
    Mr Ed.
  5. ianmidz
    ianmidz
    Looks like a DOA machine going back to the supplier today - thanks and all the best.
    Ian
