Harman vs Arcam
Discussion in 'AV Receivers & Amplifiers' started by smallangryboy, May 8, 2003.
Tags:
  1. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    I'm ready to ditch my AVR100, as it's getting a bit long in the tooth. For various reasons I don't want to get an AVR200 (price being one) and will be keeping my Arcam DV88.
    Budget will be limited as I'll only get a few pennies for the Arcam, so was wondering what HK model I should go for, old or new, for about £350 ?
    It will be driving Monitor Audio silver series speakers (8i-front 3i-rear 12i-centre) and possibly a sub in the future.
  2. ditton15
    ditton15
    Oct 20, 2002
    536
    16
    edinburgh
    having just bought a sub, I'd recommend that as next step.
    ditton
  3. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Would that be to get the sub first and listen to it using the Arcam amp, or as a next step after changing the Arcam for an HK reciever ?
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Change you amp first as it seems to be toast. The HK 2550 is just within your budget, but perhaps a bit low powered at 40WPC (yes, I've heard HK underestimate)? Get the sub second as it will all sound pants if your amp is faulty anyway.
  5. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    Say I was to replace the amp, and I have a budget of say £350 - 400, what could I get that would be similar in sound and performance to the Arcam - obviously at about £400 cheaper than an Arcam AVR 200 I have to compromise somewhere but I do like the sound of the Arcam
