Harman Kardon tuner
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Brox, Nov 20, 2003.
  1. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Have just bought an HK tuner on ebay it's the TU909 firstly does anyone know of this model?
    it may have a small fault but since it cost very little i'm not too bothered. In seek mode the only station it picks up is classic fm, otherwise you have to manually select the frequency ans save it as a preset - does this indicate a fault or is the tuner not very sensitive and the signal not strong enough?
    The tuner sounds fantastic - as good as my Sony 920, and i'm very pleased with it aside from this fault.
    Can anyone shed any light on this issue
  2. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Mystery solved - It was a faulty aerial connection, it's not quite as good as the sony but very close, excellent for the money.
