Harman Kardon DVD 25
Discussion in 'Blu-ray & DVD Players & Recorders' started by mjn, Mar 3, 2003.
  1. mjn
    mjn
    May 24, 2001
    17,651
    Herts, England
    +4,561
    Anybody out there using one of these players.
    I'm looking to pick one up, when i'm over in the UK at the end of March.
    Just wondering if there are any known issues/problem i should know about before purchasing.
  2. Big_AL007
    Big_AL007
    Never heard of any problems and I have had none with mine.
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,648
    UK
    +112
  4. rauer
    rauer
    Feb 17, 2001
    424
    +7
    Some people seem to have a problem with this player and the Sanyo PLV-Z1 projector and I'm unfortunately one of them. With progressive PAL material there is sometimes a horizontal flickering artefact. Some people believe it has to do with the player having a too-high-voltage video output signal. Some have managed to get rid of the problem by routing the video signal through an AV receiver.
    Another minor issue is the zoom function. If I'm correct, one should be able to pan the zoomed image. However, I haven't been able to do it either with the original or the hacked firmware. No big deal.
    Oh yeah, there's just one SCART so you can't chain gear.
  5. DownToTheBone
    DownToTheBone
    Nov 20, 2002
    156
    London
    +4
    There's a first tests review in this months what hi-fi ... they liked it alot ...
    DTTB
  6. retrof
    retrof
    Feb 28, 2001
    155
    +14
    Got one last month from Germany - fantastic player. Wasnt willing to take the risk on the initial bugs with the 963sa, and the HK goest for around 399 euro in Germany if you shop around (plus 50 or so for shipping) - still quite cheap.
    I'm using it with a Sanyo Z1, and the progressive output on both PAL and NTSC is excellent.
    -rf
  7. marcw
    marcw
    I'm on the brink of buying one of these myself. Only questions I have are:
    Is there a noticeable lip sync problem when using Prog Scan?
    Can it play, erm, not totally legit DVDs? The ones with the purple surface on the underside... I occasionally get films pre-release on this type of media and want to still be able to play them - my aging Sony DVP-S715 can...
  8. rox
    rox
    Hello, I have bought also the player yesterday (with Z1...?...simply fantastic!!!!) :D :D :D
    But with the Z1 it works alone in 480p (or 480i), is it normal?
    With PHILIPS 963, the Z1, works to 575p.
    Which of the two is better?
    It's the 480p inferior?
    rox
  9. rox
    rox
    Sorry, one other question:
    can you select PAL in the menu of the DVD25 or, when you set progressive, it set NTSC without possibility to touch it.
    infinite thanks
    Rox
  10. rauer
    rauer
    Feb 17, 2001
    424
    +7
    That's what happens with an unmodified player, it is only able to output progressive video as NTSC/480p. However, with the hacked firmware from the link above you can in addition to having a region free player also output true progressive PAL/576p (= 575p).
  11. rox
    rox
    I have not upgrade the firmware becose my S.N. is advanced to that one described on H/K site:
    http://international.harmankardon.c...=DVD&ser=DVD&prod=DVD 25/230&language=ENGLISH
    H/K say:
    >All DVD 25 players with a serial number bigger than
    >WA0001-12582 contain the latest firmware.
    >If the last part of the serialnumber of your DVD 25
    >is lower than these numbers
    :boring: :boring:
    ...I will proceed with the upgrade... :smoke:
    Rox
  12. rauer
    rauer
    Feb 17, 2001
    424
    +7
    rox,
    that fw you mentioned is the official one so it can't provide region free playback and probably still not progressive PAL. The fw from the apache site is a hacked one and provides both.
  13. rox
    rox
    I have verified the dimension and the creation date, these are apparently identical files....
    rox
  14. rox
    rox
    ......therefore the quality of the image could be still better that I has seen yesterday?
    If yes :clap: :clap: :clap: :clap:
    mmm :p
  15. mjn
    mjn
    May 24, 2001
    17,651
    Herts, England
    +4,561
    i wouldn't using the progressive scan as yet, and if i did, it would only be a stop gap, til i got a iscan, or something similair, and a CRT projector.
