Harman Kardon DV25 Multi Region DVD Player
T
thewolf
I am planning to buy a new 32" CRT TV with progressive scan support and component input, probably a Thomson WB 642 S.
I will have to buy a new DVD player with progressive scan support and component output.
What do you think about the Harman Kardon DV25 Multi Region DVD Player?
Specifications
* MP3 Decoding
* CD-R/RW compatible
* 10-bit video DAC
* 1x Scart (RGB Compatible)
* Component Out (Progressive Scan Compatible)
* Progressive Scan for PAL & NTSC discs
* Backlit Remote Control
* 24bit, 192KHZ Wolfson Dacs for Audio CD Conversion
* Optical & Coaxial Digital outputs
* Auto region playback
* PAL & NTSC PROGRESSIVE SCAN
* Power Requirement: AC 90-240V/50-60 Hz
* Power Consumption: 6.5 W
* Dimensions (H x W x D): 441 x 84 x 324 mm
* Weight: 5.4 kg
Description
Single-disc DVD player with progressive scan video output.
Experience maximum clarity. Unlike conventional DVD players, Harman Kardon DVD 25 features Progressive Scan Video Output for maximum resolution when used with compatible video displays. On the audio side, 24 bit/192 kHz audiophile-grade Wolfson digital-to-analog converters deliver enhanced audio playback. When you add built-in MP3 decoding, picture zoom, multiple search speeds and a backlit remote control, there isn't a more capable or versatile DVD player out there.
The Harman Kardon DVD 25 - the ultimate home entertainment component.
I've found it on sale for about 120 euros (80 pounds).
Thanks!
P.S.: What do you think about the Thomson TV? How do you compare it to a Panasonic TX-32PD30D?
Crocodile JD
Established Member
The only place I found it for 120 euros was on an e-bay auction in some country or other. What will the highest bid be? Where did you see it??
Croc
T
thewolf
I apologize for posting the wrong price, the actual price is 270 pounds!
Ciao.
hornydragon
thats still a good deal mate 506 is similar money and although DVD2550 same specs as DVD25 were available for £260 recently the price has gone back up to £300
T
thewolf
Originally posted by hornydragon
So they are and the cheeky chappies are doing the DVD25 for £250 too
What is the difference between the DVD25 and the DVD2550?
Thanks!
C
Coaxial
Mate, get a 25 at that price, silver or not! looks / sounds better than any of the competition below 500 squid, but admittably get's it's arse kicked soooooo far by the Arcam 88..
maybe you could pick up an 88p on ebay?
othewr than that, the Pioneers are canny, but aren't stereo players, and the Denons are a bit behind the competition IMHO.
indiejones
Established Member
⭐ Philips OLED+908 TV preview + REL subwoofer and Avid Accent amplifier reviews + Hi-Fi & AV News
Back
