Harman Kardon dv25 any good ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jas, Dec 11, 2003.
  1. Jas
    Jas
    Jul 14, 2000
    87
    Lancs,Wigan
    Hi Everyone i feel quite tempted by this machine
    could any one who owns one then please leave your comments hear.
    Thanks to all who may reply
    Jas
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Love it.
    Improved picture & sound over my Tosh SD220, even more so when using prog scan which is why I bought it.
    I use a projector so differences picture quality show up a lot more than they do on my 32" TV.
    HTH
  3. LDJ
    LDJ
    Jun 18, 2003
    605
    +27
    does it play absolutely everything you throw at it? dvd-r/+r/+-RW/cdr/rw? any disks or brand of media youve tried that it wont play?
  4. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    To be honest I don't know. I have a different set up for music so I wouldn't use the HK for cd's let alone cdr's.
    I have a Philips DVDR70 therefore use dvd+r & +rw. I use the Philips to playback these disc's. All my other discs are norml pre-recorded material, all regions.
    I'll try a +rw one in the HK and let you know.
  5. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Seems to play +rw ok.
  6. LDJ
    LDJ
    Jun 18, 2003
    605
    +27
    thanks. :)
  7. stevo67
    stevo67
    Apr 27, 2003
    54
    9
    Hi Jas
    I have had this dvd playa for about 6 months now in reply to your question about palying dvdr etc etc
    then it seems to me that it is the usual story,that it depends on what type of dye type the dvdr is.As I have had problems with certain dye types.I prefer ritek go4 dye .Dvdrw seemed to play up as well but these were mainly princo
    No probs with cdr or cdrw
    hope this helps
  8. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    Good unit, piccy and sounds both very good. Had a few issues with recorded disks, mostly non-finialised discs but some fiddling seems to resolve (power on / off with disc in).
    Backup discs work fine.
