Harman Kardon DV22 is multiregion dvd?
Discussion in 'Blu-ray & DVD Players & Recorders' started by vicsay, Apr 20, 2005.
  1. vicsay
    vicsay
    Hi everyboy, I like to buy a dvd player Harman Kardon DV22 but my only question is that if this player is multiregion, because I like to play dvd's from region 1,2 and 4.
    In some pages say that is region 1 and 0, but others say that is only region 1.
    Thanks.
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    It can be modified by remote control code to be multi region
  3. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    made mine multi region via the remote took all of 5 seconds :D
    there are several hacks available depending if you have the latest software upgrade (available from hk web site)
    if you buy the player from sevenoaks hifi they will give you a print out of the hack :smashin:
  4. vicsay
    vicsay
    Ok, well I going to buy the dvd player from circuitcity.com, and I don't think that this company give me the hack to make it multiregion.
    Well, the Firmware is to updgrade de dvd player to play dvd's of region 2.
    But where can I find the hack to make it multiregion by remote control, because I search in some pages and I can't find it.
    Thansk. :)
  5. vicsay
    vicsay
    I Found one hack, but I don't if it work.
    Someone now if this code work?
    3, 1, 4, 1, 5, 9, 0
    Thanks again
  6. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    that was the code i used
    sorry but in my original reply i did not realise you are in mexico :cool:
    best ask your supplier for details :D
  7. vicsay
    vicsay
    Ok, thanks, well circuitcity not send products out of usa, but I have a friends that live close to Brownsville and he can buy me the dvd and send me to México, but I like to now about de dvd player before I buy the product, in specific about the regions that can play, because I have dvd's of region 4 and 1 and coming soon I going to buy a dvd of region 2.
  8. parkem50
    parkem50
    Mar 12, 2004
    34
    Norfolk
    HI,I was thinking of buying this player myself, to match my hk 630 amp. Can you guys give me the run down? I have a pioneer 525, quite old. Will the HK be an improvement? what do you think? Any info welcome, build quality, cd playback, looks! I rarley get to a hifi shop that sells HK stuff.
    Many thanks.
  9. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    i love my hk dvd22 played using component to panasonic viera plasma :D
    best deal i got at the end of last year was £199 from sevenoaks hifi - which at the time was £100 less than other shops - there may be better deals out there now
    i made it multi region as noted and i have never had a problem playing any regions - it has NEVER refused to play a disc which is more than can be said of a lot of players - no macroblocking either
    i use it in progressive mode as found this gave optimum quality with my gear
    oh and music sounds fine on it as well - although to be honest if you are into serious cd music there are better players out there at a price ;)
    all in all well recommended
    hope this helps
  10. Mep
    Mep
    Dec 25, 2004
    9,542
    +468
    samjet...have you ever had any problems with your remote.....i.e. using the navigation buttons in a dvds menu (scene select for example) it sometimes loses the picture (seems to invoke v off mode when you press the down arrow) or other times it just takes you back to the movie?
  11. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    touch wood not had any problems :D yet!
    now i'm going to get bloody paranoid waiting for this to happen :eek:
  12. Mep
    Mep
    Dec 25, 2004
    9,542
    +468
    i've had two and they both did it....very annoying
  13. OneDesi
    OneDesi
    Mar 10, 2005
    8,113
    Black Country
    +242
    I had the pioneer 575 (had 636 before that) which I upgraded to a DVD 22 as Sevenoaks were/are selling them for £150. All I can say is that the DVD 22 blew away the pioneer in temrs of detail etc and I thought the pioneer was a great upgrade from the 636. I would almost say that pound for pound the DVD 22 was better than the Denon 2900 which I tried on the day that was going for £600. The extra money wasn't worth it!
    Hope this helps.
  14. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    all very true - its a superb player imo - and i've seen £1k+ players
    the fact is that its not an 'in fashion/trendy' player or company :D
    what really amazes me is that people keep raving about denon players yet there are dozens if not hundreds of posts about everything from macroblocking to software bugs - and yet people keep buying them :suicide:
  15. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    Well I guess its down to personal opinion?
    I had a lengthy demo of the HK 22 and found it to be shockingly bad - a real lack of detail, blacks werent all there, and found a Pioneer 575 to be better in all areas. Pity, as I was looking for an upgrade - Compare a HK 22 to the likes of a Denon 2910 and you'll be shocked to the difference, the mid-range Denon's are in a different league.
  16. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    don't know what you used as a display with the dvd22 but with the panny viera plenty of black and detail :D
    as i said too many issues with the current range of denons :(
  17. Mep
    Mep
    Dec 25, 2004
    9,542
    +468
    pq damn good with my panny too!
  18. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    one point i should perhaps make is that my dvd22 is connected straight to the viera with high end component leads not through av amp (direct route = pure signal:D ) and audio is handled through high end coax to av amp (yamaha 750)
  19. vicsay
    vicsay
    Good opinions, the post was for know if this player can be multiregion.
    But I like that make opinions about the dv 22 to know if is a good dvd player to buy.
    Thank :)
  20. dustyscoins
    dustyscoins
    N.B. this player is not Multi-Region as default. To activate Multi-Region simply follow these instructions: Remove any discs from player / Put player in Standby mode / Press and hold 'Clear' on remote control while powering back On / Press OSD on remote to bring up menu / Enter the following code on remote: 3, 1, 4, 1, 5, 9, 0 to select region free mode / The player now resets and is region free
  21. lupo
    lupo
    Jan 22, 2004
    100
    Berwick upon Tweed
    +6
    Hi all,
    I am quite intersted in this player, what is it like for layer changes.
    I have a Pioneer 444 it is not that good, my old samsung 709 was better.
    Thanks for the help.
  22. vicsay
    vicsay
    Thanks dustyscoins for the code. :thumbsup:
  23. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    put it this way i cannot tell when layer changes takes place with my dvd22:D
    hope that helps
