Harman Kardon AVR330
Discussion in 'AV Receivers & Amplifiers' started by Unlight, Sep 20, 2004.
  1. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Hi there, After almost settling upon a Denon 2805, Ive stumbled across this lovely beast.
    However, I can find next to no details on it!
    Can anyone tell me if it has component ins on the back panel? (I need at least 2 to route my component cables through), and also if it does S Video up conversion?
  2. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
  3. Rickyj @ Kalibrate
    Rickyj @ Kalibrate
    Well-known Member AVForums Sponsor
    Jan 29, 2003
    5,852
    Surrey
    +1,859
  4. Rickyj @ Kalibrate
    Rickyj @ Kalibrate
    Jan 29, 2003
    5,852
    Surrey
    +1,859
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HK current models dont do video conversion but they are cracking amps...... very beefy... unfortunatley the chassis and front panel arent as good as there previous models....
  6. Graham_E
    Graham_E
    Nov 8, 2004
    167
    +10
    Just to let you know:
    the xx5 range is not due in the UK for a considerable amout of time (think >6 months), he press release some people have read is from the American site, and refers to the 115v, NTSC only product, which wouldn't be much use over here..
    The 430, 630, and the DPR range do upsample from composite to S. All amps have 2 component ins, and a monitor out. One feature here, however, is that since the component switching has been designed to have minimal componentry in the signal path, the component out does NOT deliver the on screen set up displays from the AVR.
    Hope that helps
    Graham
