Harman/Kardon AVR3000 remote programming
Discussion in 'Home Cinema Control & Remote Controls' started by Kimmo, May 17, 2005.
  1. Kimmo
    Kimmo
    I am trying to find programming code for AVR3000 remote which gives me most of the buttons active so I could control my htpc more effectively. It doesn't matter if it is DVD, CD, TAPE or VID1-4 code, computer can learn them, but at least I would like to have following buttons sending signals:
    Sleep
    Surround
    Volume control
    Directional button, Set button and buttons surrounding directional button
    Numeric keys
    Keys with color codes above them
    I've been trying codes sequentially but yet I haven't been able to find programming code which meets these requirements, closest one is code 121 for VID2, only blue button not sending signals.
    If anyone has found a better programming code, please inform me about it.
    Thanks,
    Kimmo
