Hey guys.
just lookin for some second opinions.
A couple of days ago, my HK 335 decided to stop outputting any sound what so ever.
Upon further investigation, i have found that,
the pre-outs also arent working,
the full osd (to my tv) isnt working,
and although no sound is coming from the speakers, (any of them, including surround) there is definatly current there, because the speakers make a sound when i connect or disconnect them with the amp on. (yes i know thats usually a bad idea, but i wanted to check if they were getting power.)
after all that background info, my question is, do you think that it would be cheaper to get it repaired, or get a new amp,
and also, seeing as the 640A is stereo only, (system use is less than 5% movies) am i likely to get a better sound from the 640A over my 335 if i get it fixed?
Thanks.
Thanks.
