Has anybody worked out the hack to make the 506 LE multi-region? Do I just use one of the hacks from one of the other players in the family? If so, which model is it closest to, the DV22 25 or 30?
Ensure there is no disc in the tray.
Put player into standby.
On the remote control press clear while switching player on.
Press OSD to bring up the screen menu.
Enter the code 314159+region no. ie 3141591 for region 1 etc by entering a "0" as last digit you obtain "Region Free"
If at any time after a code change the player is in standby and the clear button is pressed when the player is turned on,the player will revert back to the original region code
